Winterizing Mercruiser D4.2L Engine
Jurgen
17 May 2011
Bristol Boat in Mercury
Hi All,
I need to replace the closed water coolant ready for winter.
Can anyone advise on the following points?
1, where is the closed water drain on the Mercruiser D4.2L?
2, Can I flush the system by running a hose into the header tank while the engine is running or do I need to connect the hose to another inlet?
Many thanks
Andy
Hi Andy
The coolant in there is only a year old both replaced with fresh when you bought her. You will get another season before ideally changing it.
The starboard will be drained when we remove the heads so you will be doing it twice.
