charles_reed
I find it takes a long time to get the taste of sodium hypochlorite out of the system, so avoid it like the plague.
Here in the Aegean, below zero temperatures are not sufficient a risk to drain the tank and associated pipework, though it's probably adisable on the UK east coast.
The big problem with any water left in pipework or tank is the development of anaerobic bacterial infection (H2S - rotten egg small). I've found sodium hypochlorite relatively ineffective for prevention. However, for the last 10 years I've found that one of the silver chelate compounds, put into the tank and pumped into the pipework works admirably in preventing this infection. Protection is claimed to work for 6 months, though I've found that after 2-3 months of use with ordinary water the infection recurs.
The compound I use (I've only been able to find it outside the UK) is AquaClean by Yachticon G Nagel. €12 for sufficient to treat 1.2 tonnes of water - the liquid is far better than the solid form.
When you come back to the boat you just use the water normally - silver nitrate is a very effective, but harmless to humans, bactericide - in use for over 150 years.
