bobgosling
Current (pun intended) set-up is a 55A alternator charging a
70Ah engine battery and 85Ah domestic via an old-fashioned relay switch, i.e. not voltage sensitive. Domestic is loaded with the following :
Navman 7200 DSC-VHF (has a built in digital barometer)
Garmin GPSMAP 130 (greyscal LCD low power)
Nasa Navtex
Rule Bilge pump
Eberspacher (knackered at the moment but may get it fixed)
JRC1500 Radar
Nasa Log, Depth, Wind
Autohelm ( rarely used )
Car stereo
Nav lights
Cabin lights
I have obtained an X-Split 3 output unit and want to add more to the domestic bank by adding another 85Ah ( same make as current - which is only a few months old ).
I believe that traditionally with 2 domestics one is set up as 24 hour services with the other for everything else. In my set-up that would put just the Eber and bilge on one battery. I'm thinking of adding the VHF-DSC and GPSMAP and Navtex to that battery too. With it left with a small solar panel trickle charging I'm hoping to get to the boat with Navtex loaded and VHF's barometer showing latest trend. A good 20 minute engine run to get out into my sailing area should stick enough charge into it I hope. 20 minutes back again too.
Reason for adding the GPS to the same battery as the DSC-VHF is that it just feels "wrong" to not have them on the same battery.
Does that sound sensible ? What would you do ?
Boat, 28ft Seal, is kept on a mooring with weekend "pottering" use and hopefully next year a cross channel trip.
Nasa Navtex
Rule Bilge pump
JRC1500 Radar
Car stereo
Nav lights
Cabin lights
