Window seal
plumbob
18 Oct 2009
Bucks
I need to seal between the window frames and the superstructure ( you know, the plastic) on my old Birchwood , and would prefer to use the "putty" type of sealant as opposed to mastic. We use a similar stuff in the plumbing game to apply to the underside of sinks. Trouble is, it only comes with a sink.
They supply it on a cellophane backing , usually in about 25mm widths, which would be just right..........about 6 meters of it............but where from ??? Any advice?
some links for you
pts plumbers merchants,,,, grahams plumbers merchants may have some on a roll maybe try screwfix also
Hi, this 3M product may fit the bill
3M 5313 Butyl Strip Sealant 20mm x 10m
Price:*£20.12*
Product code: GT500069452
: Current Rating 4.7/5
NEW Write Review | Read Reviews
Multi-purpose butyl sealant strip direct from 3M - a world leader in tapes and adhesives technology. This sealant can be used in both interior and exterior...(more)g
This Product is Available
P&P: £2.50 or Free for orders over £20
Typical Delivery: 1 - 2 Days
How many
Product Details:
High strength butyl sealant strip for use in both interior and exterior applications
Highly aggressive adhesive sticks to almost any surface
Exceptional weathering
Easy to apply; oversized liner means no picking at the edges
Perfect for use in outdoor home repair such as bonding guttering to walls. Can also be used in repairs to motor boats, caravans and automobiles.
Colour = Black
Multi-purpose butyl sealant strip direct from 3M - a world leader in tapes and adhesives technology. This sealant can be used in both interior and exterior applications and it sticks to almost any surface including brick and concrete.
IMPORTANT: We recommend that you test products prior to use to ensure suitability. 3M can accept no responsibility for accidents resulting from the misuse of 3M products so if you need any guidance regarding applications or product selection, please call the 3M Tapes & Adhesives helpdesk on 0870 6080050. Open weekdays 9am-5pm.
Have you tried good old plumbers mate, this works well in bedding wastes ect in sinks
:confused::):confused:
Back in the 1970s I moored on the Hamble. Along my Pontoon was an American called Dave Cable. He was the M.D. of the 3M Company Europe. I was forever having leak issues with my Toughs Cobra 33. He brought me a tape which I applied to the outside of screen. It worked like magic and didn't look unsightly.
I have no idea what the stuff was called but it looked and felt like insulation tape that an electrician uses but was quite obviously thicker and stronger.
Uxbridge Boat Centre
Waterloo road
Uxbridge.
01895 252019
Have bought mastic tape there before myself.
Once you have visited their chandlery, you will return....
Reading Marine Windows.
Hi Brian.
Have a word with the above.
I have used them and been very pleased. Price was good and no leaks.
If you still want to do it yourself, I am sure they will tell you what they use. Sounds like the product you are describing.
Mike
Many thanks to you all............I have plumbers mait but I am not keen on its long term use, we dont use it on sinks anymore, silicone is much better, but sets to a rubber consistancy and doesnt stick too well to anything with flexing. I will trawl the results you have kindly given and therein will lie the product Im sure.
Thanks also to Mike...............my mentor !!
PM me if you get stuck. I have mate who is a window/glass specialist in Staines. Not marine, but he does good work and knows his pane!
