Hydrozoan
Having just removed a saloon window for refurbishment, I thank PBO and the author for this well-illustrated and helpful article: https://www.pbo.co.uk/expert-advice/renovating-boat-windows-27718. It is I think likely also to help owners of other Sadler models, and perhaps of other makes too.
A few hints:
(1) As well as adding the protecting tape on the stripping/filler knives as shown, I also ran a length on the coachroof side around the edge of the frame.
(2) Getting a knife into the lower edge of the frame to cut the sealant to the coachroof was difficult because of the limited space above the side deck. An old table knife with a flexible steel blade, honed near the point, was very helpful there.
(3) For the same reason, prying the out the bottom of the frame was difficult, yet necessary because the frame was a tight fit in the aperture and had to come out square. I resorted to inserting a large wood chisel sideways into the ends of the lower frame and gently twisting it. To try to avoid this next time, I shall make up a few small J-shaped aluminium pry bars and hope that by inserting the (sharpened) short end of the J upwards under the frame they can be levered gently against the coachroof side below, to help pry it out evenly.
I will now reset the glass in the frame, but have an enquiry about sealing the frame back into the GRP. The article and other accounts I have read recommend Arbomast BR butyl sealant and that is probably what I shall use. However, one hears also about butyl tape for sealing deck hardware and I wonder if anyone has used it for sealing window frames into GRP? My reservations are that it may not be thick enough, and that it may not be possible to get it round the tight bends without introducing vulnerable joins. Any experiences would be much appreciated.
A few hints:
