Tidewaiter2
Said windlass sluggish last season, ran then stopped for a breather, ran again, etc, etc. It's a SEAWOLF from Simpson Lawrence- prob original fitting to 16 year old boat. Surface mounted, with electrics in chain locker. Has to have engine running due to current drain.
This year, nothing at all when switched on and footswitch pressed.
Dismantled and cleaned UP only footswitch, nothing.
Checked visible electrics for loose/corroded connections, tightened/cleaned, still nothing.
Traced all wires-found wires from footswitch and batteries/motor to what looks like a Relay Switch. Battery/motor wires run to two substantial terminals on top, footswitch to two small ones at side of top.
Has Name; Albright in red, TYPE: SW80-374P, Voltage:12, Made in England.
1) Would I be right in thinking this is a 80 amp Relay Switch?
2) Could We replace with an 80 amp waterproof Circuit breaker?
3) Or should we replace Like with Like?
Footswitch wires to small terminals on side of top heavily corroded. When I tried to free them to clean them up and test system, one terminal/pole loosened inside the casing and now rotates and lifts!!
4)Suspect the corrosion here may be the cause of our windlass problems last season?
5) Could also be brushes on motor?
Any advice gratefully received, got a friend with crocus paper,who can deal with 5) on boat Thursday/Friday, but now need to buy replacement for Albright ?Switch before then. Preferably more seawater resistant!
Cheers
Dick T.
Cheers
Dick T.
