PaulJS
Hi Everyone,
I'm afraid I'm at work at present so can't access the manufacturers website, so I'll try to get advice here.
My boat is fitted with a Quick Windlass, 700W, horizontal motor in the chain locker, vertical drum and gypsy on deck, my anchor is 20kg.
The first time I tried using the anchor it kept on tripping the circuit breaker, even when lowering.
Further investigation revealed a dry soldered joint at the breaker and that it was Quick 20A unit (at the time I didn't know the windlass power rating), so presumably bought at the same time as the windlass. However 700Watts/12volts = 58+ Amps, so as I can't access the website I don't know if this is correct; do Quick recommend a circuit breaker rated at 1/3 of the winch available power for an anchor of 20kg or is the breaker totally inappropriate.
Looking at the cable sizes which are at least 8mm diameter, I'm very suspicious that I should have at least a 50A breaker as I can't find a 60A one.
Any advice gratefully received,
Paul
Paul
