Nigelb
If the windlass circuit has a breaker within 150cm of the battery, do I still need fuse protection at the battery?
Also the Lofrans website for a 12v Tigres recommends a 100A breaker but the data sheet for the windlass has a load of 160Amps?
If I use the Blue Sea Circuit Wizard (App) it calculates a breaker or fuse rating of 175-200A?
Getting very confused!
Batt 820 Amps MCA
Voltage 12v
Load 160 Amps
Duration <1min
Wire 50mm2
Single Run
Outside Engine Bay
Batt 820 Amps MCA
Voltage 12v
Load 160 Amps
Duration <1min
Wire 50mm2
Single Run
Outside Engine Bay
