Sailingsaves
Summary first: If a fuse is used when installing a wind turbine and the fuse blows, the turbine will be damaged (possibly beyond repair) would it not?
Discussion:
If a wind turbine is connected to a controller that allows dumping etc, would a fuse from the turbine before the regulator (or even after) be a BAD idea (If the wires are thick enough and protected from ever shorting) .
Because if the fuse blew, the turbine would continue to turn and the current has nowhere to go and hence the stator will be damaged?
But many manuals state a fuse should be used.
If the wires are thick enough and protected from ever shorting, can a fuse be omitted for the sake of not killing a turbine?
Discussion:
