artemis07
Active Member
Nearly two years we were unfortunate enough to be caught in an 100knot "event". The wind generator ran out of control causing the blades to shatter sending shards, at very high speeds (hundreds of knots), in all directions. Luckily they all missed me. On returning to the UK I informed the makers who immediately refuted my complaint. It was impossible they said, they are indestructible they said. They accused me of not fitting it properly, which wasn't true. They said I hadn't used their equipment so the blades had touched the mast, I had used their mast. Incidentally, their performance graphs stopped at 40 knots so I presumed they hadn't tested their product above this speed.
Anyway, fast forward to this year. I started chatting with the crew of boat which was caught in the same "event". Their wind generator blades also shattered, they actually saw them disintegrate and regarded themselves lucky not to be injured or even killed. It was the same make as mine and also used the maker's mast.
Be warned, if you have a wind generator and winds of 60 knots or more are expected put a physical brake on it. The 100knot "event" was not expected. The wind generator had an electrical brake but the regulator "fried" before the fuse melted.
The good news, new blades were fitted and a very expensive new regulator was purchased (from the wind generator manufacturers). It works perfectly.
