Chris_Stannard
See also the posts in 'Heavy Weather Making me Nervous'.
From personal experience, coming in through the Needles against a spring tide and with a 6/7 SW, everything the pilot says is true. Because of the shape of the channel. between the reef and the Shingles Bank, standing waves build up and these can be enhanced by the incoming waves so you can end up with 12 feet plus. I came in, with a full racing crew, in those conditions. In the troughs you seem to lose the wind, and on the crests you are in severe danger of a broach. Because the tide runs at in excess of four knots it feels like it takes for ever.
The standing waves are also there on the incoming tide, so again if the incoming sea has the right period the stading waves will get enhanced. You also get the turbulence of the water beyond the reef
In strong winds SW the answer is to use the North Channel, which is easy to find even at night. I guess you might get a window at slack water when the conditions calm down a bit.
One tip from the Yarmouth Lifeboat, if you are going out of the Solent with the tide go half way between Bridge and the Needles. This is well clear of the wreck on the reef, you have about 7 metres of water, and you avoid the problems in the Channel. If you need a way of judging this keep the old Coastguard Cottages above the top pf the Needles light.
Chris Stannard
Chris Stannard
