Boo2
THis is a 5 year old thread - started again by a new person after a gap of 3 years. Can we not stop these somehow?
What for ?
Boo2
What for ?
Boo2
As others have said, is anything new being said? It brings a dead topic back to life, loads of people respond to what they think is a live issue.
What we really need is a good search engine and then use it before posting questions. There have been several/many threads starting with the same weather query. I am always happy to try to answer them but sometimes go back and copy a post from a previous thread to do so.
There is chapter in Reeds Weather Handbook on the tidal stream/ wave issue.
That's all very well , but this is a discussion forum. If we only wanted to know 'the facts', there are probably better sources than YBW forum that Google and other search engines could find for anyone sufficiently keen enough to follow up.
I think the mix of views, observations, perspectives, solid expert information and insights from people such as yourself, plus a generous dose of blind prejudice and wilful provocation from hither and thither, is what makes the forum entertaining and informative. That, and the way that subjects come up (or resurface!) that one probably wouldn't have set out to research, but is pleased to have drawn to one's attention, engage with, and perhaps gain some insights from.
Long live old threads!
Maybe the moderators could use the code system to illustrate that a particular thread is over a certain age?
Such a system has been in place for some considerable time. It's in the format DD-MM-YY and accompanies the name of the OP, just below the title of each thread. Granted, the reader would have to do some fairly tricky arithmatic for this elaborate code to fulfill the function you describe. Those not up to the task could perhaps get their carer to help.
It's almost a brilliant post.
Except that this thread is still active as indicated by the name and date of the LAST post ;-)
I’m adding to the resuscitation rather than starting afresh. It’s a long and rather techie post, and in the end it won’t tell you how big the waves will be. So don’t say you’ve not been warned!
But I hope - with that warning - it may be helpful. And as the late John Ebdon used to say: ‘Anyway, if you have been, thanks for listening’.
snip...
Lapworth’s paper (http://onlinelibrary.wiley.com/doi/10.1002/wea.606/pdf) cited by franksingleton at #89 covered A - and said of its subject: “... the phrase ‘wind against tide’ … should really be ‘swell against tide’ …”).
...snip
Personally, I prefer 'wave train against current' as it is more general than 'swell against tide' and correctly summarises the physical effect.
Lapworth's paper is so clear that I keep a copy on board.
Excellent stuff! It's great that you've highlighted that there are two different issues, given that a lot of the thread seemed to me to be people talking past each other because they had missed the distinction.
… Personally, I prefer 'wave train against current' as it is more general than 'swell against tide' and correctly summarises the physical effect. Lapworth's paper is so clear that I keep a copy on board.
