orgescott
Hi Guys, just started a new job and was faced with an electrical problem (new to boats).
The winch at the rear of the boat is controlled by a Vetus handheld box with a curly lead terminated with a three pin plug. No problems when it is connected to its 3pin socket at the rear - the winch raises and lowers perfectly.
When at the bridge the Vetus can also be plugged in but, does not work, traced a multicore cable that is connected to the wiring via a set of 4 miniture relays.
This cable returns into the bow of the boat and lays just underneath where the winch is located.
The multicore cable has been stripped back - should there be another box attached to this cable?.
Kind regards
Kind regards
