Winch servicing - white spirit OK as cleaning solvent?
LittleSister
12 Nov 2007
Is white spirit OK for cleaning old grease & dirt off during winch service?
Lewmar instructions say paraffin, but we would rather use what we have in surplus already if suitable, rather than adding to our stock of flammable clutter. We also have meths and petrol if they were preferable to white spirit.
prv
29 Nov 2009
Southampton
I can't imagine it would damage anything - it's fairly mild as solvents go. So if it dissolves the grease ok then I would go for it.
PuffTheMagicDragon
I use diesel, of which I have an abundance on board. It is not as readily flammable as white spirit and does not create as much fumes. Petrol I would avoid totally due to the fire hazard.
AntarcticPilot
4 May 2007
Cambridge, UK
www.cooperandyau.co.uk
Basically, I've used all of the above, and perhaps a few more (including meths). I've found that when dealing with old, coagulated grease slathered on before I owned them, none of these solvents is terribly effective! They're OK with grease that is still soft, but old grease dries to a hard, varnish-like consistency and I've found that no solvent really touches it. My brother had a go at them with a car degreasing setup, which circulates hot caustic soda solution and that has been more effective.
Moral of the story - REALLY only use the smallest smear of the appropriate lubricants!
guernseyman
21 Feb 2005
Guernsey
White spirit is often used for cleaning greasy machinery. It can leave an oily deposit, which will usually not matter for such use.
I use methylated spirit or acetone if the oily deposit is to be avoided.
Vara
20 Feb 2004
Canterbury/Dover
i am told...cos I wouldn't dare do this at home! That a session in a domestic dishwasher at most aggressive programme, makes short work of that hardened grease.
Not recommended for bearings with plastic holders though.
PeteCooper
16 Jan 2005
West of Scotland
Just a wee note here - something that I found out by accident ... some plastics are dissolved by some versions of turps substitute. I left a brush in some of turps substitute in a plastic jug, and when I went back the liquid had disappeared, then I noticed that the liquid was in the bucket that the jug was stood in and the jug had a hole in it. Fortunately this was in my garage.
So if there are any plastic bits in the winch I would be careful, and also be careful what container you use to wash the bits in.
xyachtdave
9 May 2009
MYC
Thank goodness for the thumbs up from the forum for white spirit use.....
Havethis weekend completed 4 winch strip downs using the most suitable cleaning product available from my garage - white spirit!
The sexual purring of our recently serviced winches makes me very happy.
savageseadog
19 Jun 2005
I find white spirit to be poor as an oil or grease solvent. The best thing apart from industrial degreasers is Kerosene, ie central heating oil. Diesel is probably OK too but kerosene tends to be cleaner all round.
