Williams 285 wiring diagram
itspaul
19 Jun 2010
Home staffs Boat Mallorca
Hi all I wonder if anyone has or knows if there is a wiring diagram available online. ? I’ve had some problems with mine today misfiring and eventually stopping and refusing to start I’ve identified that I have no impulse to the injector on the rear cylinder I’ve had the rail out and checked it’s not the injector just no impulse so I need to try and trace if it’s an electrical break so where.
Thanks.
Hi thanks for the replies I have been in touch with Williams this has only confirmed my fears and they have supplied me with a wiring diagram for the textron 750 which is the engine I have, this has only confirmed my fears that the ecu has developed a fault. Under running conditions the injectors have a 12v supply to one terminal on the injector and the ecu earths the other to create the pulse I’ve checked all continuity on the cables which check out fine so this just leaves the ecu.
These are NLA from Williams and an obsolete part so my only hope is a used one ….. Any help will be gratefully received .
Plenty of auto electronics specialists who repair ECUs. Perhaps one of those could help?
Usd1300.
https://weberpower.com/mpe-marine-143hp-engine-management-system.html
Could I ask a favour. Could you post the wiring diagram on the Main Williams thread please. It maybe useful to others
I would also perhaps get the local Williams agent to scan it with their tool given the cost. It maybe someting that can be reconfigured / re flashed
