Rum Run
I will be adding a pair of 6w LED daylight running lights under the spreaders to act as a deck light. They have no tricky regulating electronics so should be no problem to the aerial coax which runs up the mast.
However, I am considering adding a dimmer to the deck light circuit to reduce the consumption if used as an anchor light, say down to 20% duty cycle. If I use a 555 chip based dimmer running at around 1khz, will it interfere with the VHF? The coax and the deck light supply would be in the same conduit. Length of cable around 7m.
Cheers
Rum Run
Cheers
Rum Run
