aidancoughlan
I'm currently tackling the headlining in my Westerly Merlin. The chainplates go through the side decks, and are visible in the saloon.. and the old headlining was done before the chainplates were fixed with bolts.
When I bond the sheet of headlining to the cabin sides, I will have to cut it to go around the chainplate, and then join it back up with a seam behind the chainplate. It will take a bit of messing to get a decent finish afterwards - I'll have to build a box to cover the square plate & hide the rough-cut edges.
An alternative would be to undo the bolts, disconnect the chainplates do the headlining and then re-fix the chainplates..... while the mast is up.
... has anyone tried supporting the mast temporarily like this? Anyone done headlining without removing the chainplates?... If I support the mast with a halyard merely tied to the stanchion bases will it be safe while I do the job ? What if I dont get it finished & have to leave it for a week supported by the halyard?Should I drop the mast to do it properly ?
thanks for any info/tips/answers to any of these questions..
