Wifi USB Booster - What to Buy?
Richard10002
17 Mar 2006
Manchester
Having tried loads of things, I now have a 5m low loss cable with a 9db omni outdoor aerial which I haul up to just below the first set of spreaders.
It has an RP-SMA connector and, until recently, it was attached to the laptop with one of these USB adapters on the end of a USB cable:
http://cgi.ebay.co.uk/ws/eBayISAPI.dll?V...A:IT&ih=015
However, the flimsy construction of the USB adaptor means it is now U/S and I am considering what look like more substantial alternatives:
would you get this:
http://cgi.ebay.co.uk/ws/eBayISAPI.dll?V...A:IT&ih=001
with what I think is a 200mw booster
or this:
http://cgi.ebay.co.uk/ws/eBayISAPI.dll?V...A:IT&ih=019
which has a 500mw booster
or something completely different?
Cheers
Richard
orizaba
28 Jun 2007
PORT YASMINE HAMMAMET TUNISIA
www.mtmarineservices.com
the best one i've found is by a company called repeat it.
robust comes with 30m cable,designed for marine use,picks up signals up to 2k away guaranteed, all electrics are in the ariel box so no power loss. the one i have is an RS/3.
i think they may have brought out a new model ,its not maybe the cheapest but well made waterproof,and designed for the job, uses standard usb input and proper h/d cables,
google repeatit and see the site.
still not heard from my mate in malta re wifi but will let you know as soon as i do
sarabande
6 May 2005
I have used the Repeatit receiver and it picks up signals from up to 3km away.
OK , it is directional, but it's powered from the PC, and has great support from these people who supply MDL marinas and lots of commercial centres.
www.wifispark.com
Only connection is that of a satisfied customer.
fredcb
20 Mar 2007
Don't forget its illegal to just pick up and use any old signal!
If its just a marina WiFi you want to use I have found any good quality internal wifi modem on board with with its built in aerial will work in grp and timber hulls with line of site to the transmitter.
thalassa
2 Feb 2003
www.wv-saeftinghe.nl
After a series of disappointments with cheap USB dongles, cables and added frying pans as "boosters", I bought the Senao USB adaptor last year, and haven't found a marina yet where I couldn't get a decent signal.
12 Aug 2007
Currently La Coruna Spain
if you use a usb adapter with rp-sma connector to something like a 9dbi antenna (Realistically probably around 6) you will have no problems in most areas. The trick is to make it weatherproof, buy a small plastic construction box, pop the unit inside with antenna sticking through a hole in the box, usb cable attached, and fill it with epoxy..
I actaully use a cantenna made from a spaghetti tin, superb, the electronics are "potted" the same way. CGeap and it works.
I DO have a 500mw amp that I use occasionaly. Can make all the difference. As for being illegal to borrow bandwidth, yeah, so are lots of things.
Have fun
Abigail
6 Oct 2002
South of France
www.sailblogs.com
Is anyone using one of these with an apple mac? We use both a mac and a pc on board and the aeriel on the Mac is significantly weaker, and I could really do with a strong wifi booster. We use a passive Dlink inside a cantenna, which does help but doesn't really do as well as we would like.
Ta for any advice.
