laika
1 - The Pico/Bullet needs to be set as DHCP, so this hands out IP addresses etc. If you don't do this you won't be able to get onto these devices later to select your network
Small point but...with this set-up isn't the problem that you have to have your Bullet powered up to use your internal network? I recognise that some "home routers" may be restricted in how you can set them up (e.g. their dhcp servers not allowing you to specify another router) but with increasing use of IP networks for nav data, you might well want your internal network powered up when not needing to waste power on (potentially non-existent) external connectivity.
In other news: I'm considering a bullet: how have others mast mounted these? None in shops for me to look at and I'd like to consider how I'm going to attach it before ordering it.
Obviously I intend engraving my name on it before putting it at least 15m away from me...
