Wifi extenders.
john_morris_uk
3 Jul 2002
At sea somewhere.
Any opinion on the latest best wifi extender nowadays? I’m thinking of something that picks up a wifi signal from ashore from a greater range than a laptop or phone. It then becomes a router onboard for on boat devices. I guess one that takes a SIM card for 4G or 5G would be advantageous?
My googling only comes up with Digital solutions at over £600 so far. I’m sure I’ve seen other systems at boat shows for cheaper.
RedFrog
17 Aug 2018
Pepwave MAX BR1
It's LTE/4G there are 5G versions available too. Can offload to marina WiFi amongst other things. You control how much signal from the various sources should trigger the switch (4G/WiFi/Lan). We just connect everything on the boat to that. Can also set up VPN if you are inclined and connect remotely to the network.
These are used on coaches and the like to to provide decent connectivity in a moving environment. We ran a Netgear MR1100 for a while, it was not reliable for us. The Pepwave has been up and running for the best part of a year, I can't remember having to touch it. We stream a Google Security Camera over it too. I don't tend to offload onto out marina WiFi as it's pretty dire, we just put an unlimited Vodafone sim in it.
Frank Holden
23 Nov 2009
Cruising in the Golfo Corcovado
I just buy a local SIM and make my iphone the hub. Cost in Ecuador is $US12 for 30days/14gig - which lasts two of us about a week.
Benefit is that it works in remotish - away from marinas - anchorages and also when you catch a bus up into the hinterland.
KompetentKrew
27 May 2018
Tether to your phone and hoist it up the mast in the first instance. This can transform an anchorage from having infuriatingly unusable internet coverage (if the phone is in the cabin) to perfectly fine.
If you're not using tablets and laptops, and you need to keep your phone down below to browse on it then get a cheap 3G / 4G router / hotspot and hoist that up the mast.
Note that the US uses different cellular frequencies from most of the world, but the Caribbean seems to be the same as Europe.
Zing
7 Feb 2014
I have had a Ubiquiti bullet for years. Highly recommended. However, I mainly use 4g now with a mifi router.
yoda
12 Dec 2001
Tamar river, Devon
John, have a look at this.
QK-R041 Marine Wireless 4G LTE Router - Quark-elec - NMEA 2000 & Marine electronics
Neil
Martin_J
19 Apr 2006
Portsmouth, UK
Can that last one (QK-R041) connect to shore based WiFi?
I only skimmed through its spec but it looked like it's WAN connection (to the Internet) is either via a wired router or cellular only.
Martin_J
19 Apr 2006
Portsmouth, UK
Same with the Pepwave BR1, the MiFi devices and phones on hotspot mode.. which of those can repeat the shore based WiFi and fail over to their cellular when out of Wifi Range.
Seven Spades
30 Aug 2003
Surrey
There are two different things. There is on-board WIFI created by a router that takes a 3/4/5g sim and I find these work great. They are more problamatic when roaming because data is limited and gets eaten easily. Then there are wifi extendersw where you try to connect to a shore based wifi like a resturant you have visited and use that connection to make a wifi on the boat. Then there are devices that do both, they will route via another wifi if it can connect to one or it will use the sim.
My experience is that few shore based wifi will allow you to share data with a boat based repeater. The MAC address of the extender identifies itself as a repeater and so it gets blocked by default in an awful lot of places. What you find is that you can connect but nothing happens. Then you connect your phone or lamp top to the same network and they work fine. However if you are in Scotland I find that you can connect to the free wifi on the CalMac Ferries which was particularly useful in Barra when my 4g provider did not have any signal.
Robin
30 May 2001
high and dry on north island
Years ago we had a Maplins little gizmo like a mini satellite dish, worked really well but maplins long gone. problem AIRC is you need 2 way transmission source to receiver and receiver back to source, there must be a similar device out there and most likely even better.,
TSB240
17 Feb 2010
I have been using a Teketonika RUT 950 this year.
It can have up to two sim cards for mobile data and will connect to shore based WiFi.
I have used them in industrial applications for remote access and control.
Range can be extended considerably by add on antennas. I have found the standard unit is bringing in signals to the boat that my mobile phone never picks up.
Typically available on ebay for less than £100.
Ningaloo
19 Aug 2001
Northern summers on Primal otherwise Perth WA
yacht-primal.com
Another budget option is the GL-X750V2 4G LTE Smart Router which costs around £100. This offers boat network (wifi and wired) and connects to internet via marina wifi (or phone hotspot) with rollover to a 4G SIM if this is not available. Can also accept external aerials although I haven't found the need to do this. 12V power and low current draw. Much the same as the Teketonika but around half the price unless.
I have one and it allows me to monitor my boat instruments and security camera from AU.
Martin_J
19 Apr 2006
Portsmouth, UK
Like TSB240, I also have the Teltonika RUT950 which can use either WiFi or Cellular for its WAN (Internet) connection, as can the GL-X750v2.
The GL-X750v2 looks similar and is perhaps more compact and probably faster on cellular but I can't see what voltage PSU is needed for it. The RUT950 can be powered by anything from 9v to 30v.
(Correction - it looks like the GL-X750v2 uses a 12v PSU so easy to power on board).
How much did the shipping and import taxes come to for the GL-X750v2?
SandyP
20 Sep 2021
Many business routers will have removable antennae so they can be connected to high gain ones
Directional antennae are also an option and not difficult to make, but not ideal if you're putting it up the top of the mast
Combining wifi with mobile sim, yes, they exist but it means you have a single point of failure
Martin_J
19 Apr 2006
Portsmouth, UK
I wasn't really asking the question for myself. I just wanted clarification on one of the suggestions.
The original poster asked about a device that would reach the internet using WiFi and then provide WiFi/wired connectivity for devices on board.
The response giving the Quark R401 didn't appear to meet the requirement in that it does not appear (on it's own) to be able to connect to a shore based WiFi, unless I am mistaken.
goeasy123
10 Nov 2018
In which case can you plug the Alfa's USB antenna directly into a laptop without the router and get it to work... I wonder?
