Trevethan
Why my dinghy won\'t plane
I now know my my recently acquired tender won't plane with its 9.5 hp engine -- only going on one cyclinder.
Outboard is older evinrude. lower clylinder doesn't fire.
So-- checked the spark plugs . seem OK. Swapped them, but still only top cylinder fires. HT cable is fine.
At one point managed to get both firing, but that was short lived -- seems it tries sometimes, but fails. {;enty of fuel coming out so no not carb.
A friend said there might be a little water getting in as it sort of coughs from time to time.
Took of head, and gasket appears fine -- but will replace. Failing that what else? the crank case seal? If so how much and can anyone suggest somewhere around london?
Cheers,
Nick
Cheers,
Nick
