William_H
Have to have a go..... Language of course is a fluid thing changing all the time so lets noty argue about what term means what. All you have to do is make the listener understand what you mean.
Certainly in some circumstances sail boats will not tack. This is often in rough seas and heavy winds where the elements cvombine to stop the boat before it has turned far enough through the wind to get under way again. Cats are notorious and some monos are worse than others. If it won't tack then you gota jibe.
The main sheet on a bigger boat should be pulled in as the boom comes across and released as the boom swings out on the new leeward. The slow releasing of the sheet and the friction of the tackle combining to gentle the inertia of the boom as it swings over to stop. The crash on arrival can be 'orrible.
No one has mentioned the technique of backing the jib when tacking is difficult. This usually involves leaving the jib cleated tight on the old tack so that as the boat turns through the wind the wind hits the back of the jib turning it inside out. The thrust on this angled sail turns the bow even further in the direction you need. Once the boat has turned far enough you change the jib to the correct side for the new ttack. The converse is that if you pull the jib across to the new side too soon before the boat has passed head to wind the wind on the angled jib will push the bow back or stop it turning.
As I said sometimes the wind and waves frustrates even this technique and gybing is the only way.
Finally yes teaching and explaining yacht actions can be difficult in the pressure of things out of hand. Maybe you should give your teacher another chance. If not teach him...
.....olewill
.....olewill
