Latestarter1
Yes, one gear is enough to cover the needed speed range, but having more gears would save fuel at lower speed.
The prop is usually designed so that the engine can just reach the max power RPM. At this operating point you will utilize the rated maximum power of the engine. If the max speed is for example 8 knots, and you slow down to 6 kn, then the required torque to push the hull through the water will be much less. As a result the engine will output a torque which is much below the maximum available torque at that RPM, which means non-optimum fuel economy. (= consumed diesel/produced mechanical work) Having the possibility to switch to a bigger gear would reduce the RPM further and thus increase the torque taken from the engine to be closer to the max torque at that RPM. (the prop torque would remain the same)
Please google “Brake Specific Fuel Consumption Maps” to see how the fuel economy depends on the RPM and the torque.
Simply not true, somebody else who has their automotive head on and does not understand the basics of marine propulsion and the fact that propellers move boats, engines merely respond to propeller demand. OP was brave enough to ask the question, which has exposed others who wrongly think they understand.
Bsfc is a characteristic of an engines full load curve. In a boat a diesel engine responds to the propeller demand curve NOT the full load curve.
Let me provide an example: Perkins M135C hax maximum rated power of 125Hp @ 2,600 rpm, correctly propped 100% of power absorbed at rated speed.
Nobody rushes about pedal to the metal, nice cruising speed for this engine is 2,000 rpm. Potential power at this rpm on full load curve is 108 Hp. However if we assume displacement vessel with say 2.8 exponent propeller will be demanding 60 Hp, cruise a little slower say 1,600 rpm, potential power is 93 Hp but propeller is demanding 30 Hp. Where is the missing horsepower? The engine is not producing it, throttle is setting RPM, governor merely adjusts fueling to hold desired rpm. Fuel burn relates to power demanded not potential power.
Diesel engine consumption is always on the propeller demand cure for a given exponent and never on the full load curve.
