JimC
This looks like the stuff
www.lidl.co.uk/cps/rde/xchg/lidl_uk/hs.xsl/index_9515.htm (taken from the YM forum)
Where's the evidence for that?If you use untinned wires but spray the exposed copper generously with a silicone spray, the silicone will not only prevent the exposed copper strands corroding, it will penetrate a long distance up the wire under the insulation (many metres) and the result will be, to all intents and purposes, as good as if you had used tinned wire.
On boats which myself and others have owned, on which the method I described has been used with complete success over the past 18 years or more with no deterioration in electrical performance to date. The strands of the conductors, where visible, are bright copper with no black oxidisation. Moreover, the highly penetrative nature of the silicone oil means it gets into every interstice so that terminal screws and spade connectors etc stay clean & un-corroded and don't seize.
Consider the auto pilot failing just when you need it on a single handed night sail and you'd wish you'd done the installation correctly.
Also consider the time and cost of re-wiring any major job in a few years time just because you didn't use tinned cable.
