GSL
C'mon Jimmy, the suspense is killing us here
Graham
Graham
The Optimate chargers in fact do this, but you'd not expect the battery to remain at 16 volts once the charger is switched off.
Graham
I have had siilar experiance with a cheap chineese voltmeter, as the meters internal battery fails, the meter overreads.
had siimlar readig, 12.4 batt showed 17 volts.
Yes we are, whew! It turns out that I've got a duff voltmeter - so total forum respect to Pete who first asked the question and Mark who suggested the BATT indicator about 100 posts ago.
Using the _good_ voltmeter, the battery is showing 13.1v. I guess my supplementary question is - how can I tell if this battery is definitely u/s - will the unloaded voltage drop over a relatively short period of time?
Cheers
Jimmy
(I think I need another cup of tea after all this high drama)
Oh, I almost forgot......when are you planning another trip to the civilised West? It would be good to see if we could meet up!![]()
Jimmy - when you mention Optimate, is that the m/cycle charger ?
I have a couple of the 4s with the clever charging routines for the bikes, but the output is only designed for batteries up to 50 AHr with a charge current of 0.8 Amp.
I suspect they will take for ever to charge you 170Ahrbatts - if they ever manage to do it.
You have to be aware that they will give silly readings if the battery start to go though!
For a 170Ah battery you should be using a charger with max output getting on for 16amps.
A smaller one will do it but take a long time. 3 amps though just is not in the game at all. Suitable for batteries below 40Ah really or as a maintenance charger for larger ones.
Get them on a decent sized charger and charge them each until you can get a reading of at least 12.7 volts 24 hours after coming off charge. Preferably nearer 12.8V.
Monitor them for a week or so. A good battery will take several weeks to fall below 12.6v
Even if they seem OK on this basis it does not guarantee them to be good for service but if they fail the above they are not likely to be much good.
Devices such as security stuff, gas detectors, pumps, even a fridge, may be wired permanently live.
If you have a clamp ammeter or can scrounge the use of one, you will be able to trace if there are any demands being made when the main switch is off.
A decent clamp ammeter (e.g. Kewtech 2056R) is invaluable on board for tracking where the juice is going, and has AC and DC volts, continuity, and temperature as well. Worth considering.
is there a reason why I couldn't just wire a shunt in series with the domestics and use a regular ammeter?
Yes you can do that but is an ammeter not already fitted to the boat?
Anyway: ebay might be my friend, again:
http://cgi.ebay.co.uk/New-DIGITAL-C..._Measurement_Equipment_ET&hash=item3a655631e7
You ceratinly could wire a shunt in the domestic battery circuit.is there a reason why I couldn't just wire a shunt in series with the domestics and use a regular ammeter?
Using the _good_ voltmeter, the battery is showing 13.1v. I guess my supplementary question is - how can I tell if this battery is definitely u/s - will the unloaded voltage drop over a relatively short time a)
