ip485
So there is no possibility of it hitting your head.
Certainly this can be a bit of an issue above 36 feet or so.
To a degree it is not purely the boom height that causes a need for mast steps - a fully battened laminate sail with quality batten cars tends to be quite high above the boom when stowed.
One minor but very important suggestion from our recent experience - get a stack-pack/lay-bag. But make sure the zip closes from the boom end towards the front NOT the other way around. It is relatively easy to start the zip at the boom end with very little sail there. Then pull forward as far as can get to and sort the rest at leisure. The alternative of aligning two zip ends and starting the zip from the front requires 3 hands, telescopic arms, patience of a saint and vocabulary of a Glaswegian![]()
On a recent delivery I noticed the stack pack zip was sewn so that it over-shot the sail at the clew end by several inches and just hung loose. When unzipped it didn't come apart at all, but opened enough to let the sail and lines through freely. So to zip up one just had to pull the closer back along the zip. Clever I thought.
UV amongst other things.
We cruise in the Caribbean. UV is fierce. We cover up at every opportunity. My friend didn't cover his sails so often and after 5 years you can rip them by hand like a sheet of paperI'm even more amazed at the need to zip up except at the beginning and end of a cruise. On a recent month long cruise it was undone at our starting marina when the boat was snugly tied up then done up again at our destination marina. Particularly when we are at anchor I want to be able hoist the main with minimum fuss.
