pagoda
Charge controllers ("smart" regulators) can't produce more current than the alternator was designed to produce. This is certainly or self evidently true - but with a traditional regulator and a starter battery being up or near full charge most of the time, the belt doesn't have to transfer much power for very long. My point was (and I think you are agreeing with me) is that a 90 amp alternator charging a large house battery bank that is allowed to run down a long way, can be asked to produce near it's full output for a longer period. Actually, in practice, the alternator gets hot and self limits to a degree (if you'll pardon the pun).
However I suppose my supplementary question should have been, "Have you fitted a bigger alternator?"
That makes sense.
I make a point of not having too much running (fridge in particular) when starting the engine after a period of non-running (or after a long passage normal sailing with lights/ instruments). Just taking it easy for the first 5 minutes avoids most of the furious initial re-charging / belt slip.
We have the standard Hitachi Alternator for our 4jh4AE with 3 x house batteries, 1 engine and 1 thruster battery.
There are some belts available which though nominally the right length are too narrow and sit deep in the pulleys. Ours are flush with the pulley rims.
