Who's the best people for changing seals on Volvo DPD legs in the Solent area
beeks
21 Aug 2010
Hi all,
Just removed my out drives to changed the bellows and found the oil contaminated with water, I picked up a line last season and found a large melted piece line between the props.
I have made a pressure tester up and found the seals between the contra rotating shafts leaking, had a look online and it looks like special tools and pullers are required for the job.
Any advice?
Ian
Hi all,
Any advice?
Ian
Where are the drives at present, I can fit if you wish.
You could go to Bucks to take a look at the drives instead Paul with you being Midlands based. It'd avoid Beeks needing to take the drives back down south unless you need to see the boat too
