gilesfordcrush
Hello all,
I have searched the forums, and can't specific find an answer to this.
I have a Whitlock Cobra steering system fitted to my 1978 Moody 30. I was unhappy that I could not remove the top cover from the pedestal, the four bolts were seized. After several evenings of hard work I have removed the broken and snapped studs from the aluminium casting. My next job is to clean up the threads of two of the holes, as they are a little damaged. If this fails I will need to oversize the holes a little and re-tap.
I'm hoping to be able to run the tap down the holes and get the threads clean enough to accept the new bolts. Is tapping aluminium different to steel?
I did not have any problems with the steering, but I'd like to inspect it, clean out the old grease etc. Can anyone advise what type of grease I should use? It is a rack and pinion type mechanism. I can't find any documentation regarding how to take it apart, or in what order, can anyone advise?
Many thanks,
Giles
Many thanks,
Giles
