Whisker-poles: a dangerous practice?!
Don't use the genoa sheet, and run the spare sheet that you do use through a snatch block on the end of the pole to reduce chafe.
How is this snatch block set up, John? I have a pole with pistons and a snatch block on a becket - are you just suggesting it's clipped on to the piston? It looks a bit clunky and likely to tear one or the other apart.
