Krusty
Over tha past couple of years I have read a few posts about using whisker-poles on headsails: one even recommending it for running in strong winds: 'just clip it into the clew-ring, and on to a ring on the mast and away you go!' (Or words to that effect).
I was taught, by one of the most respected exponents of good seamanship, NEVER to clip a pole to a headsail clew; that such a practice was an abomination to be shunned at all times, and any skipper who sets up his yacht to run before a breeze in that way is accepting than anyone going overboard is going to die.
Why? Because in an emergency the yacht it severely restricted in its ability to manoevre until the headsail has been unclipped from the pole, (with one less crew). Meantime, the yacht cannot be tacked or sheeted to sail to windward;
heaving-to is of no help because the headsail is then forced hard on to the pole end and cannot be unclipped.
Any seaman-like method requires that the headsail can be let fly by casting off the sheet from its winch as if the pole were not there: the pole-end should only be a 'fairlead-in-space' through which the sheet can run. The pole should be triangulated in position by a pole-lift (or 'up-haul'), with fore-guy and after-guy adjustable from the cockpit. That way, the yacht can be rounded-up, tacked and close-hauled without delay: then the pole can be swung to the foredeck from the cockpit, and anyone sent forward to drop it to the deck is working on the windward side.
