Poey50
Who doesn't love an angle grinder.
Big +1 for a cordless angle grinder that you can use one-handed. Some practice needed as it is also a weapon of mass destruction.
Some years ago a friend lost his mast off the north coast of Anglesey. The motion of the boat was so violent that he dropped his bolt croppers overboard. Mine are equipped with a wrist lanyard just in case.
I have a few. Each setup for a specific job:
1) Engine tool kit with multiple service kit items and a few spares.
2) Electrical toolkit - everything I need to deal with anything 12V wire based. inc fuses, bulbs, spare wire, croc clips, and so on.
3) Woodworking toolkit - wooden boat, says it all.
4) General toolkit - for all other sorts of jobs.
5) Rigging kit, includes sewing lit, with spares
6) Spare tool bag with some general purpose tools that can be grabbed for jobs. This one has the mole grips and other bodger bits and might be the one I would lend you if you asked me nicly.
All the tools are cheap and get replaced when they start to show signs of rusting.
That mention of Snap-On reminded me of one of the most useful tools that I have on the boat.
It's a radiator hose pick and great for getting hoses off spigots but lots of other uses too.
Ahem, I think you’ll find a full size torque wrench in our boat too. And I’ll raise you a two and three legged puller.This is rapidly becoming a "who has got the BIGGEST toolkit" thread. Looking at Vyv_cox's collection, mine is pretty similar, but I've got a full-sized torque wrench, so Yah Boo Sucks!.
That's a good idea, sorting tools according to their usage. Mine are all in together, not convenient and often the one I need is buried under others. Thanks for the tip.
What I found is you need open and ring spanners.
I thought I was light on tools, but I suddenly realise I have almost as many tools as everyone else, and sadly I've had to use most.
You absolutely need tools to:-
Change impellers.
Change belts (try it, you may find it's a substantial set).
Cut rigging.
A filter wrench.
Some sealant.
Electrical crimp kit.
I think everything else I could have winged it a bit.
I looked at my tool kit earlier this year & realised that there is no point in carrying most of the carp that many of you are bragging about in this thread.
I took a long hard look at spanners & decided which ones I actually needed for the engine. No point in carrying the largest as they only fit the engine bearers. I then removed the ones not needed. I retained a pair of mole grips & an adjustable spanner.
I removed the screwdrivers & now have a slotted, a philips plus a small electrical of both patterns.
A set of allen keys
A small tin of 3 in one & a small tube of grease.
3 spare impellers. 2 spare of each size of filter & a spare belt
A slotted bolt for a filter wrench
A hammer
A special box spanner & extension bar for the prop.
Long nosed & short nosed pliers plus a pair of pliers in the hatch
Then I looked at the boxes of bolts & screws.
I removed most of those & have 3-4 of each size of bolt that I might need with nuts & washers attached to each. About 5-6 self tappers of each length, A metre length of 2 core electrical wire & an assortment of electrical connectors. Electrical tape. one of each size of jubilee clip. A pair of electrical wire cutters & a Stanley knife. HD jump leads. Rig cutters.
3 pairs of disposable gloves paper towels & hand cleaner
I have whipping twine, needles, a palm, a lighter & a small size Swedish fid
I saved Lbs in weight & if I am somewhere & find that I need anything then I will just go & buy it. I am hardly likely to want to drill holes & do major repairs at sea. Things like boxes of drill bits & drill, hose, cramps, saws, have all gone home.
None of my tools have ever gone rusty, so that is not a problem to me.
I hate sailing about with "clutter"& it just slows the boat.
For instance I have bought a Ridge Monkey & discarded the cast iron griddle pan & frying pan. Saved a few lbs. I have cut down on loads of spare gear because it just was not getting used.
It is amazing what one can get rid of, if one just sits & abandons the "it is handy even if I never use it" mentality
Throw them away? Not likely.
