UncleAlbert
I am but a simple chap who knows a little about many things but is especially not an expert in electrickery (and the wonders of Amps and Watts etc
When sailing away for days I do like to keep the milk cool and the butter hard as well as not letting the sausages and bacon go rancid, so aboard my Centaur I have a Lifeline 150 Ah Leisure Battery whose sole purpose in life is to supply volts to my Halfords cool box to achieve the above.
For the last year this battery was supplied with electricity from a second hand Aerogen 2. Unfortunately earlier this month it shattered its magnets due to centrifugal force, (and probably a non standard repair in the past looking at the amount of Araldite used to bond the bits together), in a 37 knot gust a couple of weeks ago and is therefore only fit for the scrap bin now as parts are no longer available.
So I am in the position of wanting a new wind gen to support the comestibles cooling process!!
I believe are the salient facts to solicit views are:-
Coolbox current draw as per spec sheet 3.3 amps
Likely use of coolbox continuous running would be daytime only. (Too noisy to have running when sleeping).
Would be top up charging when not on boat.
Will not be linked to other House or Start battery circuit/s.
So:-
1.Which product can you vouch for based upon my criteria as above?
2.What views does the panel have in regard to an 11kg rotating (Rutland 914i) mass 3 metres up a pole versus a 6kg (LE300) mass in the same place? Is this important?
3.Any other helpful hints or obscure turbine suppliers please. (Solar panel enthusiast need not apply
Ta Unc
So:-
Ta Unc
