Tranona
The debate on the merits of different shaft seals will run and run. The face to face seals such as PSS and Tides rely on the bellows pressure keeping the two faces in contact with eachother. They also require water to keep them cool, hence the need for injecting cooling water on high power/speed applications. Potential problems are the faces wearing or not maintaining pressure, although current designs with the bellows on the fixed part of the stern tube minimise this. Some earlier designs had the bellows on the shaft and were known to shift with water pressure coming up the stern tube. One example was on a boat that surfed and the water pressure was enough to separate the sealing faces.
To my mind for a normal yacht auxiliary the Volvo seal has a lot going for it. Simple, provides good support for the shaft, never leaks and lasts a long time. Cheaper than alternatives as well. only drawback seems to be that not all stern tubes are the right diameter, but on my installation it was a simple machining job to turn the housing down.
Not familiar with the Radice version. Their website only shows face type seals, but a better way of getting grease into the lip seals would be an improvement.
