Which sealant?
john williams
14 Aug 2010
Having thoroughly confused myself with types in sticky stuff in tubes, I need some help!
I have been making a new cabin trunk for my 28ft gaffer. The whole thing is made of sapele but will fit into a horizontally flanged large aperture on a GRP deck. It will bolted in place securely so will not have to be bonded as such. A hardwood quadrant trim will be placed over the joint. Im thinking the joints will be sealed with epoxy prior to fitting.
What I need is good flexible sealant bedding compound that can be applied under the trim,will keep the water out of the joint but not bond it permanently in place, as I'm looking at future maintainability.
All the stuff I've looked at seem to emphasise bonding.
Any help would be much appreciated
john
Vallich
19 Aug 2012
john
Have you considered Butyl Tape? I've never used it in your particular application but I have bought and used the kind that comes away from the backing which is supposed to remain sticky but able to be removed and re-used for many years.
ghostlymoron
9 Apr 2005
Shropshire
Sika comes in many versions. The 2 most common on yachts are 291i which is a sealant (although with some adhesive properties) and 292i which is a sealant/adhesive. I rarely want to stick things together on my boat with Sika but often want to keep water out. In your situation, I would use 291i.
I've started using PU40 from toolstation which is much cheaper but is a sealant/adhesive.
Davegriff
19 Jun 2010
SoF
Over the years I've replaced all the sealant on what was a very 'leaky' boat, with butyl. Grips well like an adhesive, but the seal can be broken (with effort) and then fairly easy to remove from gelcoat etc. No more leaks. Previous owner(s) had tried just about everything it seems; sika, silicone, various tapes, even epoxy; all to no avail.
skenn_ie
23 Apr 2007
Co Dublin
Jointing
What I have done, for better of for worse, is to put a strip of foam rubber under the joints, leaving 5mm or so to the outside which I then fill with Sikaflex 290DC. That way, I can easily cut through the Sikaflex if I need to remove anything. Ohh, and I have to say it .... I HATE SILICONE !
vyv_cox
France, sailing Aegean Sea.
coxeng.co.uk
I removed excess with a rag and turps whilst it was still soft. It was quite easy.
During the PBO rebuild of Hantu Biru they have been using wipes to take off excess sealant, apparently very effective. I don't have a copy in front of me just now but I mean to buy some to try. Sikaflex does seem to be one of the most persistent products to clean up when wet, the stuff gets everywhere.
Poignard
23 Jul 2005
South London
I've had good results using those wipes that come in tubs from places like Screwfix and B&Q. They aren't that cheap but the risk of knocking over a bottle of white spirit is gone.
20 Jun 2007
Live in Kent, boat in Canary Islands
www.bavariayacht.info
I've used these with great success: http://amzn.to/1kD18SY
"Specially formulated to clean hands, tools and surfaces from wet and semi-cured paint, sealant, adhesive, bitumen, expanding foam, oil, grease and even silicone ..."
Martin_J
19 Apr 2006
Portsmouth, UK
I have always used a Butyl based sealant for windows that need sealing, that are held in place using screws/bolts etc. but that might need to come out in future.
Arbomast BR has been great for this..
BUT has anyone any suggestions as to where a Butyl Tape as mentioned earlier (e.g. Arboseal GZ) can be bought off the shelf in the Portsmouth area... I've tried a few Window/Glazing places in Littlehampton but no luck so far...
alan17
12 Mar 2006
Home near Stansted Airport Boat at Burnham yacht h
Amazon
Scillyboy
3 Jan 2011
Co. Cork
I find that WD40 is very good for cleaning up 'wet' Sikaflex 291....
