which prop
chaldon3
Active Member
27 Nov 2013
n.wales
hi there guys can you help advise which propeller would be the one to use.
no info on old propeller.
however on new propeller is stamped13.5x8.75. also796 218222014-02-18 19.14.53.jpg2014-02-18 19.14.41.jpg
many thanks for your advise garry.
lister petter ac1 at 3600rpm 6.5hp
18ft gpr boat som italian gear box 2:1
hi there any one help on this subject. kind regards garry.
chaldon, it appears you have a displacement vessel, which will do 8 kts max, ish
So- I would take the prop /props to Castle Marine in Caernarfon, which must be close to you
The 2; 1 reduction is fairly standard
6.5 hp will give you 'cruising' at 3200 rpm of 5 kts I would imagine for an 18 footer
I ain't no expert Mate, just a good guesser!
Guys in Caernarfon will advise, I reckon
