Poignard
Which is the more abrasive; T-Cut or Mer?
Thanks.
T-cut has been recommended to me for restoring the headlamp glasses on my wife's car. I don't have any but I found a bottle of Mer in the garage and wondered if that was the same sort of product.
What do you think would be better than T-Cut?
I have managed to get a reasonable improvement using progressivel finer grades of WOD paper but I want something to finish off.
I bought an inexpensive kit from a newspaper ad.Thanks.
How much did you pay for that?I bought an inexpensive kit from a newspaper ad.
Several grades of wet& dry sanding discs (75mm diam), polishing compound, and sponge mop, backing pad with mandrel to fit an electric drill, UV protection lacquer and application sponge. Even a little roll of making tape
Very pleased with results ... look like new.
Good luck with your toothpaste/ T cut
I have some industrial floor polish (Zep) that might do as a lacquer but I am surpised to learn that headlamps are lacquered at all. Do they leave the factory with lacquered headlamps?I don't remember ... less than other kits i'd seen on line....... I was attracted to it because it included the lacquer .
Mer will be fine for headlamp lenses. It will just take a bit more rubbing that T-Cut or metal polish.Thanks.
I believe so.I have some industrial floor polish (Zep) that might do as a lacquer but I am surpised to learn that headlamps are lacquered at all. Do they leave the factory with lacquered headlamps?
and the first one on that link is the one I used . I did not think it was still avaialble!There are plenty of choices on eBay.
#headlight restoration kit | eBay
