DJE
The boat that we bought a year ago came with a full set of Navico Corus networked instruments and autopilot. They are still working after a fashion but the displays are starting to fail. Things are a bit better since I wired the NMEA output to a repeater display on an old chartplotter by the companionway hatch; but the Corus system only outputs NMEA data once every five seconds which is a bit slow. So I'm now starting to muse about replacing most of the old system as spare parts are no longer available.
The current cluster of four display heads directly in front of the wheel will have to go as only the helmsman can see them and then only when standing on the centreline whereas the most comfortable helming position is in the corner of the cockpit. So I am thinking of displays in pods on the coachroof either side of the companionway. This gives a viewing distance of 2.5m to 3.0m. Will standard 100mm displays be easily readable at that range I wonder? I would be looking for speed, depth, wind (possibly close-hauled wind too), heading, some sort of GPS repeater, and an autopilot controller. But the autopilot controller will have to be near the wheel unless I am going to use a remote.
The Corus transducers all seem to be working well and the wind instruments seem to be better than the Raymarine ST60 kit on the previous boat. I understand that I can get a box to convert the Corus (Airmar) speed and depth to NMEA 2000 so I might be able to keep those two. Is there any chance of keeping the masthead wind transducer? And what about the compass transducer? The Corus autopilot controller has NMEA 0183 input and is working fine so I might be able to keep that too. GPS data is available on NMEA 0183 or 2000 from the AIS transducer but I would want to feed in waypoint data from a chartplotter or computer (ideally both/either). I don't mind doing a bit of wiring myself and seem to be able to get bits of NMEA kit to talk to each other most of the time.
Then we come to the choice of displays and network. The obvious ones are Raymarine, B&G, or Garmin. Who uses what and what do you think of them? Is it easy to mix and match different manufacturer's kit now that they all have NMEA 2000?
