skyflyer
I hate heights! But I hate paying a rigger to replace an anchor light bulb, even more!
I don't feel secure in a bosun's chair - particularly as I am tall, it always feels as though I could tip over backwards at a moments notice and fall out or be left dangling upside down by my feet!
So I thought for a few extra quid I would get a safety harness, but there seems to be a bewildering array. If I have to go up the mast I use a self climber device that means I do the climbing work and the safety rope is winched in solely to take up slack, but t would be nice, once up, to be able to take up a sitting position rather than have all one's weight on the balls of your feet on a rather thin climbing step.
So - a harness that enables you to sit.
So I emailed one of the companies that do these things and have come up against 'elf and safety. A "fall arrest" harness or "rescue harness" is not designed/approved to be sat in and worked from, it seems. A harness for working in a seated position is double or triple the cost - e.g. £200-£300.
So - what I would like to know is whether there is a problem using the less expensive harness for very occasional short periods? If it can take my weight after a 4 metre fall (the design standard) it shouldn't have a problem with the static load. There is so much variety it is bewildering 3 pages of safety harnesses here http://www.fallarrest.co.uk/safety-harnesses or choose from £47 to £280 here http://www.totalaccessonline.co.uk/Products/Harnesses/Full-Body-Rope-Access
Has/is anyone used/using a harness of this sort - either type - and how do you get on?
Cheers
Cheers
