Scotty_Tradewind
Re: Which gas regulator?
Interesting............
Why GasBOAT Regulators - The technical bit
Since 2001 all marine gas systems should be fitted with a regulator that meets EN12864 Annex M.
This means all LPG regulator used in the marine market MUST incorporate either an over pressure shut off valve (OPSO) or Over pressure relief valve,
OPSO valves have proven to have too many moving parts to be reliable in a marine environment.
Due to heel and movement on a boat, the naturally accruing presence of small amounts of high pressure gas entering the low pressure side of the system is increased, this high pressure removes the grease from the valves and safety cocks, causing them to leak and seize.
Why Over-Pressure Device?
If the diaphragm fails or the internal lock-up valve does not close due to seizure, full cylinder pressure can enter the low-pressure side, resulting in a very dangerous leak at the appliance, the appliance will then need to be repaired by a skilled engineer before it is safe to use again.
This can also happen if liquid LPG exits the cylinder, due to heel or violent movement of the boat or vessel.
•Gas Cylinders can be pressurised up to 7 bar.
•Gas cookers have an operating pressure of 30 mbar.
•Appliance control valves only certified to 150 mbar.
EN 12864 annex M
•Material in contact with the atmosphere shall be suitably corrosion resistant. In particular this includes internal components above the diaphragm.
•The vent shall be on the edge of the diaphragm. In a suitable location and of suitable size to drain water which may collect on the diaphragm.
•Shall incorporate an over-pressure relief device, the vent shall be provided with a pipe connection facing downwards.
•Operating pressure specification to annex D.
•PD 5482 – 3 2005: Codes of practise for LPG installations in boats, yachts and other vessels, STATES. Regulators must conform to EN 12864
•EN ISO 10239-2000: Small craft LPG installation regulation covering all vessels built after 15th November 2000, STATES Regulators must incorporate a pressure reducing device. (OVER-PRESSURE RELIEF)
•Be suitably resistant.
•Regulators installed in vessels used in a saltwater environment must conform to EN 12863 annex M
This standard is for the design and manufacture of regulators for LPG cylinders to supply appliances installed in saltwater boats.
Main points :-
THE USE OF SUB-STANDARD REGULATORS WOULD INVALIDATE ANY WARRANTY ON OUR PRODUCTS PLUS COULD INVALIDATE THE VESSELS INSURANCE COVER! - IF IN DOUBT CHECK WITH YOUR INSURER
GasBOAT Logo
Site Map
BS EN16129 was published in August 2013, which supersedes both EN12864 and EN13786. Annex D of EN16129 refers to Caravans, Motorcaravans and fresh water boats, while Annex M refers to Sea Water Boats.
However, the requirements are similar, so we would continue to recommend that in order to be certain of meeting the specifications of EN10239 section 5 you should fit a regulator certified to either EN12864 Annex M or EN16129 Annex M
S.
EN 12864 annex M
Main points :-
GasBOAT Logo
Site Map
S.
