nigelmercier
RIP
- Joined
- 20 Jun 2007
- Messages
- 16,234
- Location
- Live in Kent, boat in Canary Islands
Dont forget that the glycol raises the boiling point as well as lowering the freezing point
Good point, thanks Vic.
Do they reduce cavitation in the liners as well?
Cavitation erosion of cylinder liners ! That's the lid off another can of worms.![]()
Did we reach any conclusion on this?My engine is a Volvo MD22, which of course is really a Perkins Prima ... What type should I be using please?
Settled on the blue stuff.
There are basically two types of antifreeze.
The conventional low silicate type ( sometimes called inorganic acid technology) is used in older engines
The "advanced", longlife, , "Organic acid technology", or OAT, type used in engines more recent than about 1994 ( and i think all Yanmar engines)
The colours can be a bit confusing ! Best go by the description and ignore the colour.
The two types must not be mixed. The corrosion inhibitors are different and not compatible with each other. (although it is possible to buy a universal topup mix)
Two years later, how did this work out for you? Should be about due for another coolant change now. Heat exchanger still happy? Any problems?
My MD22 has 2 year old green Volvo coolant (Part No. 1141646) in it and while I'm generally happy buying Perkins parts and aftermarket consumables, I'm wondering if the cheap car coolant will do the job as well as Volvo's nectar of the gods. I'd really rather not be doing this anytime soon and if the pricey juice saves me the cost of a new heat exchanger, I'll happily buy it. But only if it's actually better![]()
DC4A?
Montego engine. Any standard car A/F should be fine!
+1. I use the pink stuff.
+1. I've used Unipart pink stuff in mine (TAMD-22) for the last 4 years with no adverse side-effects.
While the "pink stuff" may or may not be sufficient, I can't accept the reasoning of "it's what the car version uses". That's fine for most parts, but not the cooling system. The key difference between a car engine and a marine engine is the heat exchanger, which is what the corrosion inhibitor in the coolant needs to protect (among other bits). So just because it's good for the car version does not mean it's equally good for the marine version with a large aluminium block that incorporates a raw water heat exchanger, exhaust manifold and coolant expansion tank.
And if the car radiator does fail, it's not only much cheaper to replace, but also can't end up leaking sea water into your engine block, causing major follow-up damage.
Things I've learnt so far:
- Both Volvo and Perkins specify ethylene glycol antifreeze only (2 year cycle), no OAT (even in the latest publications, not just the original ones where OAT was possibly too new).
- Both recommend a 50/50 or 40/60 (Volvo, optional) antifreeze/water ratio (using soft water, distilled water or pre-mixed coolant)
- Both highlight the importance of using the correct corrosion inhibitors (but do not say what those are :nonchalance
I was hoping to find the Perkins stuff for less, but it doesn't seem to be available anymore, at least not where I've looked.
Any particular reason why you have chosen to use an OAT type when, AFAIK it is not specified. Like the colour? Believed it was "better"? Wanted a long life antifreeze to avoid changing every 2 years?
Two years later, how did this work out for you? Should be about due for another coolant change now...
As this thread has been necrobumped, perhaps I could ask why it would need to be changed: for antifreeze properties, or anti-corrosion? Some of my friends were amazed that I was even able to buy the stuff!
Thanks for the info. My engine had the same coolant in for at least 10 years, the traditional type, until I changed it. Should I be worried?
