BlueChip
It's pinkish, rather than pay Yanmar exorbitant prices can I use any commercial red antifreeze?
I would investigate the overheating in terms of:
a) is the overheat alarm actually meaningful, what is the water temp in the head?
b) what is the temperature of the water leaving the heat exchanger? Is there too little seawater flow, or is the heat not getting to the seawater side?
c) Is the engine generating more heat than it should? Could be timing, either valves or injection?
d) Is the freshwater/coolant flow inadequate, or not going where it should? Can you spin the pump faster, or maybe use an electric circulator.
e) Is the calorifier installed right/is it influencing the flow somehow?
Other things to try include thermostats which might be less restrictive. I am assuming the thermostat is fully open before the alarm goes off?
In my view, motoring at max rpm in flat water may not be worst case. What's it going to do if you need to bash into wind and waves and really work it hard?
After how short a time does the alarm go off when you reduce revs?
Would you not expect the coolant temp to keep rising for some minutes as heat flows out of the head into the coolant, but the seawater flow has much reduced with the RPM, if the heat exchanger is limiting the cooling?
Interesting.I'm not an diesel engineer, but two who are have watched this engine overheat and they agree it does.
Bags of water flows through and out the exhaust even at tickover, in fact the water flow does not seem that much different at tickover and high revs. Alarm goes off usually within 20 seconds of throttling back from 3000+ to 1200-1500-ish
As this has persisted through a new heat exchanger core, new water pump, new exhaust elbow and running with thermostat removed, I still think Yanmar put in fractionally too small a heat exchanger in the 3YM30. Interestingly I have never heard of the same overheating problem on a 3YM20, which is a derated version of the same 3-cylinder engine, whilst lots of 3YM30 owners have had similar problems.
In practice I regard cruising revs as 2600-2800 which gives about 7 knots on a clean hull, about 6.5 by the end of the season, and it does not usually overheat at these revs. 3000 is often OK too, 3200-3400 will quite often (but not always) cause overheating. Apart from this the engine runs beautifully, and even at fairly high engine hours (boat is chartered) starts instantly, no smoke at any revs or power. Charterers rarely seem to run the engine hard - the ones I have met seem horrified that I regard as high as 2800 rpm as "cruising" but if I'm running an engine it's to get somewhere, and I believe in diesels getting a bit of hard work.
In this particular boat the limiting factor in "bashing into wind and waves" is keeping your teeth intact from the hull slamming, so you rarely use fullish power.
The type/colour of antifreeze will have no effect on the cooling system.
Beware, though, that using OAT antifreeze in a system designed for glycol, like older cars, can do horrible and expensive things to various components.
I have a similar problem with the Volvo MD2030 on my Westerly Corsair. Overheats when doing 3000+ rpm for 10 minutes but alarm goes off after a minute if revs reduced. I have been told that my propeller may be oversized or too large in pitch, so the engine is having to work too hard.
OAT antifreeze is, just like conventional low silicate antifreeze, glycol based
True. I should have written "for pure glycol". The OAT stuff is anti-corrosion, but unfortunately attacks bits of older systems.
I understand that its copper car radiators that the OAT is not compatible with .
Said to do nasty things to some hoses as well. Great stuff if your engine can take it.
