Which 3M sealant?
Not sure about best but I've use 3M Cavity Wax Plus to good effect on my Land Rover Disco where rust was beginning to set in on the joints of some panels that were double walled, crimped and spot-welded over.
I know that butyl tape has its fan club but I'm not a member. In my view it is engineeringly offensive in that its flexibility allows the fixings to be loaded in shear. Engineers seek to load them in tension only, with friction taking the shear load. And as said above, it oozes.
Fair comments I guess it depends on application as to what you are fitting.. non structural stuff wouldn't have an issue (apart from oozing which I have not read about but trust your assessment) I just made a note that when I get to bedding certain items I will use it, otherwise I have used polyeurathane, not silicon (a whole other debate)
Steve
