Where might I be able to obtain.........
-some cheap small lengths of plastic tubing to put in the skin fittings while the boat is on hard standing - to stop water ruining the newly, as yet unappleid antifouling ?
Tried all the chandlers at LIBS with absolutely no joy whatsover, so tried my local Aladdins Cave, same result.
The sizes are 35mm and 23mm - these are the internals of the skin fitting, rather than the internal of the tube.
Hope this makes sense ?
Try a garden centre. Or better still, try a water garden place - they have plastic tubing in all sorts of sizes.
longjohnsilver
30 May 2001
Don't really understand, surely the antifouling will get wet sooner rather than later. Anyway have you thort about a plumbers merchant?
tcm
11 Jan 2002
Caribbean at the moment
Re: um yesh
i thought i was missing summink. I mean, he waits until it's dryinsh, then plonk on the tape and then slaps around with antifoul. And dabs the other bits in the sling. A teensy bit of water may come out of the skin fittings praps if it rains once applied but not blimmin much i bet.
jfm
Jersey/Antibes
just seal off the skin ftgs with duck tape for the few hours it takes for the a/f to dry, or shove laboratory rubber bungs in em
jfm
Jersey/Antibes
Re: um yesh
TCM, thought this would get you going !
The antifoul is Seatech, by Blakes, and is water soluuble, hence don't want it to be washed off by dripping water from the fittings!
If I can't get any tubing I'll tape them off for 24 hours, which is the time the a/f needs before relaunch.
boatone
29 Jul 2001
Just a few cables from Boulters Lock
www.tmba.org.uk
Re: um yesh
shove some cheap diy softwood tapered plugs up the holes and stop worrying about it.............
Make a good job of em and you can use em again and again.....
<A target="_blank" HREF=http://www.boatsontheweb.com/galleryframes.html> BoatsOnTheWeb, Photo Gallery, Chat Room</A>
david_bagshaw
5 Jun 2001
uk
Use the nearest size of pipe & wrap masking tape round it to make it the correct size, then bung it in.
It works well as I have used the method on a shower outlet while living aboard while slipped for weeks at a time.
David
<A target="_blank" HREF=http://www.euroboating.net>http://www.euroboating.net</A>
mtb
30 Jan 2002
Bit off that , I wouldn't like to be a plumbers merchant ...
<A target="_blank" HREF=http://homepage.ntlworld.com/boats/>http://homepage.ntlworld.com/boats/</A>
