Bloater
I am in the process of fitting all-new electronics to my sailing boat.
I am fitting a Garmin system and the GPS sensor will be connected to a NMEA2000 network, however the maximum 'drop' cable length is (supposed to be) limited in length to less than the distance to the pushpit rail that the existing sensor is located. Moving the network 'backbone' nearer by buying extra cables/connectors etc is an option that I wanted to avoid as they are relatively expensive.
I therefore wanted to flush-mount the new GPS sensor on the coachroof - just in front of the sprayhood, in between two dorade vents where it won't be trodden on.
My question is: Is there a problem with this location (being under the boom)? If not, why are most of the sensors that I see mounted on pushpits (where they are likely to foul lines)?
Many thanks, Ian.
Many thanks, Ian.
