RupertW
Without formal testing (which is expensive and not practical unless you are planning to sell the lights) it is difficult to be 100% sure if a light will meet the legal requirements for brightness. However, Bebi published a paper a few years ago on what type of LEDs would be required to be bright enough to pass the 2nm test. With the best 5mm Nichi LEDs that were available at the time.
The conclusion, from memory, was that a minimium of fifteen of the best 5mm Nichi LEDs were the minimum required to meet the standard. These also needed be driven with the correct regulated supply at their rated voltage. For comparison, most garden lights have one or two 5mm LEDs of dubious quality (although the brightness of LEDs improves each year) driven by an unregulated power supply. There are alternatives to 5mm LEDs, typically using a single high powered LED with an optical system to distribute the light, but the paper did not look at the requirements for these options.
The other test is to look at power consumption of your light. Most commercial 2nm approved anchor lights consume about 0.2 A @ 12v. Unless you are buying, or building, a battery operated light which is much more efficient than the commercial anchor lights then to produce the same brightness the light will need to consume roughly the same amount of power.
Assuming they are fully charged, it would take about ten high quality AA batteries to store enough energy to deliver this power for one night. So unless your battery operated light has 10 or more AA batteries (or the equivalent lithium battery) it is unlikely (but not impossible) to meet the brightness standard. This reasonably large power requirement is why battery operated anchor lights can rarely meet the standard. The light can easily have a setting that is bright enough, but on this setting the light will only last a short time. If it is bright enough and it can last all night it needs a large battery bank and few models have this.
That’s really useful as a guide and approximation - each of our two lights has a very good glass all round lens 8 LEDs and 4 AAs which last all night - so in total it’s close to what is needed but individually not. But still very bright half a mile away in good vis.
Will keep looking for better ones to eventually replace ours then.
