Where can I get new aluminium sheaves from?
contessaman
29 Oct 2009
Got the mast down for replacement … everything.
the sheaves in the masthead are original seldom aluminium ones .. 90mm diameter , 16mm wide and a 15 my hole in the middle. Looks like the new replacements are only Available in a composite material.
I’m sticking with wire halyards so I need metal sheaves … any ideas where I can source ones of comparable size?
the old ones are chipped and damaged . thanks
PeterWright
23 Aug 2006
Burnham-on-Crouch, UK
For Selden sheaves I would try your nearest Selden dealer. If you can read the mast serial no. (engraved at the foot) the dealer should be able to look up precisely which parts your mast was built from.
Peter.
Alternatively, bin the wire halyards and go for Dyneema or one of the similar low stretch UHMPE lines.
Neeves
20 Nov 2011
Sydney, Australia.
Peter.
Why on earth are you sticking with wire halyards?
Jonathan
contessaman
29 Oct 2009
Jonathan
many reasons. I sail single handed and I love the captive wire winches. Change from wire to rope means changing the winches to big self Tailers . this leaves rope everywhere when hoisting the sail. But more than any of that, the captive winches have barely any mechanical advantage. I can feel the resistance Of my main going up and if it jams , I feel it right away and lower it a bit. Twice on other boats I’ve hoisted a main with a powerful self tailer and winched against a snag and then had trouble getting it down. Trouble I don’t fancy on my own. Each to their own but what I have works well for me and I’m sticking to it thanks.
