Zagato
British company but are they made in the U.K. or abroad? I think they are pretty good, equal to Yanmar. Anything to watch out for on a 16hp model with 50 hrs on the clock at 5 years old? Thanks.
Not if you flush the heat exchanger with fresh water after every run they don't. Galley pump, T fitting, stopcock.Thing to watch. They eat the pencil anodes. Check every few months.
The basic engines are sourced from Japan, as said above they are Kubota engines. But there is a lot of work to take a basic engine and add gearbox (which is not Japanese), pumps, heat exchangers, alternators etc. This is done in the UK just outside Gloucester.
I have a 50HP. It is based on the Kubota 2203, which is a stationary engine, much used in refrigeration plant. It has done >1500 hrs and seems extremely sound. It was fitted from new by Rustler yachts. I am very happy with it, and on the few times I have called Beta they have been as helpful as possible so I heartily recommend them.
I find my pencil anode is about half "eaten" over a summer season so not too concerned. I really do like my Beta (14) and would certainly re engine with a Beta again.
Years ago I stripped a small Kubota engine and was most impressed with the standard of construction. Polished connecting rods, beautiful castings, a real quality machine. Hope they are still as good.If you go on to the Beta Marine website you can find 'literature download' and you can download installationand user manual for your engine.
Check the rear bell housing on the heat exchanger is not leaking down the back of the engine / has been replaced properly.
Thanks for feedback folks. What are the repercussions if the heat exchanger has been leaking? Is it the same issue that the Yanmars have where the exhaust elbow rots through letting water into the engine? I don,t recall this being an issue on the Beta's!
I have the Nanni N2.14 version of the 14hp model, and it's delightfully frugal. Last summer we motored from Port Bannatyne to Ardrishaig (about 8 hours) and then went through the Crinan Canal, using under 8 litres in total. Ican't recommend Nanni, though, because it had lots of teething problems and dealer support was unspeakably bad.I've had a 14 in the past and my Bowman 26 has a 10 with about 400 hours on it now. These two "mini twin" engines have been very reliable and the fuel economy is unreal - I get 2/3 to 3/4 litre per hour with the 10!
… With respect to the anodes, I seem to recall it being suggested on this forum that the issue was that when the heat exchanger was new, anodes would be consumed more quickly. Once they developed a thin coating of scale (or whatever) the anodes would last much longer. They would stay that way provided the heat exchanger was cleaned manually (I used a long thin screw driver just the right diameter to clear out the tubes). By contrast, cleaning the heat exchanger matrix by soaking it in acid had the effect of removing that layer, and then the anode would be consumed more quickly again until it built up once more. Regular cleaning with acid = faster depletion of anodes. Whether that's true, I don't know. I never had the problem.
