Firefly625
Fit a second!
If you operate them in opposing directions, does the bow raise/lower?
I have to admit I don't understand that. The existing thruster is nicely faired in to the hull in order to minimise disturbance to the water flow but the new thruster sticks out like a zit on a teenager's butt. If the owner wanted more thruster power why didn't he fit a more powerful thruster in the existing hole and if necessary, enlarge it?
Actually thats probably a better explanation. I can imagine that manouvering a single engined Nordhavn around a tight windswept marina might be a bit bottom clenching if the bowthruster fails. The other possible explanation is that I guess the original bowthruster is hydraulically powered and may depend on the wing engine being powered up to high rpm to operate at max efficiency. The owner might have thought that an instantly available electric thruster is more useful and a wise back up for a wing engine that sometimes won't start?or perhaps they had a bowthruster failure and decided they needed a spare! That's almost a better excuse.
Quite possibly, the most silly modification of a fine boat that I've ever seen.
Well if she's a Nordie 52, it's quite likely that she already has one...Why not fit a stern thruster instead?
I think it's not a bodge.
http://www.nordhavneurope.com/thruster-upgrade-n43-wandering-star/
Though definitely unusual.
Garold
good spot, and sorry for misleading folk that it was a 52, looked bigger than a 43 from walking past it quickly and taking a snap! Although certainly can confirm it has a stern thruster (I think they all do as standard..)
Is this actually the same boat? The facebook page for Wandering Star seems to suggest the work being done in January 2015 whereas, from your picture, it appears that something has been done quite recently.
Maybe having a second bowthruster is becoming de rigeur for Nordhavns?
