Kinsale373
I experienced a sharp intake of breath when removing the access panel to run some wiring through the steering binacle on my bene 373. A double run of steel steering cable comes fron the Quadrant and turns up at 90 Deg to the wheel over two pulleys. When I removed the plywood access panel in the aft cabin, I noticed appoximately an egg cup full of very fine metal dust. It looks like it been sanded off something. It does look like Aluminium casting material. I can't see where it is coming from. The Boat has the Bene System for turning the wheel at 90 Dec to make acces to the cockpit from the transom easier. The Turning mechanism seems perfectly free. Turning the wheel seems perfectly free and no rough spots.
How does the Steel steering cable attach to the Steering Wheel. Is it just a friction fit over a pulley wheel , or some other mechanism to prevent slip ?
Just wondering if anyone has experience of a similar issue before I go pulling things apart ? Has anyone stripped down one of these systems
Regards, Kinsale 373
